Posted July 11, 200717 yr comment_214799 Does anyone know of a better, perhaps less expensive source for OEM bolts, nuts & washers to connect the halfshafts to the rear diff & hubs?This is a often seen auction on eBay......set of new genuine NOS datsun hardware for 1970-1978 datsun 240z,260z,280z.Also 1979-1983 datsun 280zx.These are the bolts,nuts,washers that attach the halfshafts to the rear differential.This is enough for 2 axles. $22.99.I would need two kits to bolt to the diff and the wheels.Thanks in advance. Link to comment https://www.classiczcars.com/forums/topic/24857-source-for-halfshaft-bolts-nuts-washers/ Share on other sites More sharing options...
July 12, 200717 yr comment_214896 That price is pretty reasonable. Link to comment https://www.classiczcars.com/forums/topic/24857-source-for-halfshaft-bolts-nuts-washers/#findComment-214896 Share on other sites More sharing options...
July 12, 200717 yr comment_214911 Sounds pretty reasonable to me...Might as well do it right the first time, and be done with it......webdawg1 Link to comment https://www.classiczcars.com/forums/topic/24857-source-for-halfshaft-bolts-nuts-washers/#findComment-214911 Share on other sites More sharing options...
July 13, 200717 yr comment_214961 I grabbed some of these from eBay. That's the going price. Link to comment https://www.classiczcars.com/forums/topic/24857-source-for-halfshaft-bolts-nuts-washers/#findComment-214961 Share on other sites More sharing options...
July 13, 200717 yr Author comment_215003 Thanks for the responses. I'll pick up a set from eBay. Link to comment https://www.classiczcars.com/forums/topic/24857-source-for-halfshaft-bolts-nuts-washers/#findComment-215003 Share on other sites More sharing options...
