what kind of front lip is this?
driftmunky
First, I must say that is one sweet Z.:love:
The headlight covers look good with that stripe that lines up wtih the body lines. Wish I knew the answer. Also note they did A line on the side marker lamp.
I dont think that's just black tape. It would be easy ta paint on. With clear plastic you would paint the line inside the cover. Then you cant scratch or chip it.
It might be tape, if they are racing the car on the track, most sanctioning bodies require some sort of tape over the light lenses to prevent the shards of glass, or plastic from being spread all over the track. If it isn't, it does look pretty good on the headlight covers.
If you mean the front air dam, it looks like a common urethane air dam, most any Z parts supplier has one like it. This one looks a little different in that most have brake cooling ducts, while this one is solid. Also available in fiberglass, but they don't stand up well to curbs as well as the urethane.
  • Who's Online   1 Member, 0 Anonymous, 658 Guests (See full list)
