Help with clutch
mars23z
Well I just had my L28 put in my 260z. The engine is running great. Saturday I went to park it in the garage and now I have no clutch. I got under it and can feel the linkage has come off. I believe this is to the throw out bearing. It looks like the ball on the end of the cable has pulled out of the ring. I was wondering is there a place with schematics that would show the clutch assembly? Also do you know where I can buy the ring if thats what I need? I think if the ball has pulled out the ring will worn to the point that it cant be fixed without replacing. Thanks Chris.
Well it ended up being the slave I replaced it and now it works fine. What I was talking about was undernieth were the clutch mechanism is there is like an arm rather then a cable the part that activates the clutch. Since there was no hydrulic pressure it felt like it had come out and I was thinking that it fit into a ring I was wrong of course but I was doing this in the dark in my driveway and since I had never really worked on it before I was guessing. Sorry for the confusion and thanks for the help. Chris
