Just got back from Gateway today - SCCA Regional racing. 102 degrees in the shade - only two Z cars today.
280 ITS
and 1970 240 EP car - kind of what mine is going to be like (except I'll be faster :classic:)
https://www.classiczcars.com/forums/topic/2494-zs-at-gateway/
Had to get some shots of these two GT-2 6 Cylinders Jags - full tube frame with fiberglass bodies - the red one has a solid rear axle, the black one was independent. Super fast and awesome sounding!
Hey Rick. Whats the compression allowed in EP? I have been arguing with a buddy of mine (325IS). His is 10:1, and I have read that Z's are allowed 12:1. That info is rather old (mine), so I was just wondering.
Mike
According to the GCR:
Comp Ratio limited to 12.0:1. Cylinder head prep per I.T. specificiations except that the head may be milled to achieve max compression ratio (I.e. no porting, stock valve job, no chamber mods). Valve Life: .500" max. It can also be milled to utilize O-rings to replace or supplement a cylinder head gasket.
You can change the cam, rocker arms, valves (must be stock diameter), guides, seats and springs.
The bottom end can use a cylinder block from any model from the same manufacturer which is dimensionally identical. Can also have a billet crank, Corillo (or any type) rods, aftermarket pistons 1.2mm larger, aftermarket flywheel (same diameter - but can be lightened), any clutch assembly except carbon. Can use any oil pump including a dry sump. Also can use any type of windage tray and/or accusump. You can also remove the disty and change to a crank fire system.
Someone gets a beer on this one... I'll buy the first round!
