Posted July 19, 200717 yr comment_215664 I just droped Ruby, my 1977 280Z, off at a mechanic who specialize in Z cars here in town for a dianostic.Well the problem is Ruby has been running kind of truck'ish lately and the Mechanic (mech) has found 5 things wrong.1) The engine Block is a N42 and the Head is a N47.He said the pistions have built up carbon on the tops and are now hitting the bottom of the N47 Head.My main and most important question is What kind of head gasket thinkness do I need to buy to get the proper clearance and were can I buy one at. A place like Nappa Auto Supply maybe?So to I can either get a thicker head Gasket to fix the clearance issue or buy the correct Head which I believe is a N42 or pay about $600.00 to have head work done on the N47 to make it compatible with the N42 Block.Any help on this issue first would be appreaciated.Well Just FYI the other 3 problems are2Crack in the Air Cleaner boot letting in "Unmetterd Air" ($80.00)3 After market Fuel Pump running at 6lbs below preasure even at it's maximum setting causing it to run lean on gas. So that has to be changed ($400.00) 4Modified Throttle Switch "turned all the way to one side and bent supposedly to cover up the other problems".I suppose to max out the fuel output (unqouted price)5Clogged #6 Fuel injector.Mech said if the fuel pump is replaced the raise in preasure might be enough to ungled the injector.Thyanx for any help at all as I don't won't to leave it at the Mech jus yet~Z~ Link to comment https://www.classiczcars.com/forums/topic/24944-piston-clearance-problem-need-help/ Share on other sites More sharing options...
July 19, 200717 yr comment_215678 $400 to change a fuel pump? Link to comment https://www.classiczcars.com/forums/topic/24944-piston-clearance-problem-need-help/#findComment-215678 Share on other sites More sharing options...
July 19, 200717 yr comment_215682 If they would pull the head to install the new gasket, why not just pull the head and clean off the tops of the pistons, and while they're at it, maybe see if the oil rings or valve stem seals are bad and causing the problem in the first place. Link to comment https://www.classiczcars.com/forums/topic/24944-piston-clearance-problem-need-help/#findComment-215682 Share on other sites More sharing options...
July 20, 200717 yr comment_215757 ya, sounds a bit extreme for "carbon build up" Link to comment https://www.classiczcars.com/forums/topic/24944-piston-clearance-problem-need-help/#findComment-215757 Share on other sites More sharing options...
