I just droped Ruby, my 1977 280Z, off at a mechanic who specialize
in Z cars here in town for a dianostic.
Well the problem is Ruby has been running kind of truck'ish lately
and the Mechanic (mech) has found 5 things wrong.
1)
The engine Block is a N42 and the Head is a N47.
He said the pistions have built up carbon on the tops and are
now hitting the bottom of the N47 Head.
My main and most important question is What kind of
head gasket thinkness do I need to buy to get the proper
clearance and were can I buy one at.
A place like Nappa Auto Supply maybe?
So to I can either get a thicker head Gasket to fix the clearance issue
or buy the correct Head which I believe is a N42 or
pay about $600.00 to have head work done on the N47 to make it
compatible with the N42 Block.
Any help on this issue first would be appreaciated.
Well Just FYI the other 3 problems are
2
Crack in the Air Cleaner boot letting in "Unmetterd Air" ($80.00)
3
After market Fuel Pump running at 6lbs below preasure even at it's
maximum setting causing it to run lean on gas.
So that has to be changed ($400.00)
4
Modified Throttle Switch "turned all the way to one side and bent
supposedly to cover up the other problems".
I suppose to max out the fuel output (unqouted price)
5
Clogged #6 Fuel injector.
Mech said if the fuel pump is replaced the raise in preasure might
be enough to ungled the injector.
Thyanx for any help at all as I don't won't to leave it at the Mech jus yet
~Z~
If they would pull the head to install the new gasket, why not just pull the head and clean off the tops of the pistons, and while they're at it, maybe see if the oil rings or valve stem seals are bad and causing the problem in the first place.
