Email logins are now active ×
Tranny and diff types? Help
I bought a parts car a few years back intending to use the 5 speed and diff out of it. Now that I finally am getting around to the swap, I dont know the years of the tranny and diff or the gearing of the diff. How can I find this out? Is there a number somewhere on the parts I can look at?
there are numbers stamped on the ring gear . Or you can hold one Axel companion flange still and rotate the other one . Count the revolutions of the drive shaft flange. Mark the flanges first. One full rotation of a Axel flange and the drive shaft turns 3.9 revolutions this is the ratio. Others can tell you how to identify the tyranny's. I cannot help you there. Gary
The different transmission styles are shown on the <a href=http://zhome.com/ZCMnL/tech/69-83TrannyShifterDrawing.jpg TARGET=NEW> Z Car Home Page</a>
Note the Top Cover Plate on the 72-79 four and five speeds, there is none on the 80-83's
<a href=http://zhome.com/ZCMnL/tech/GearRatios.html TARGET=NEW>Transmission and Rear End gearing </a> is listed there also.
FWIW,
Carl B.
What about this issue?
What's the deal with these moustach bars. The one with flogged out rubbers (blue) is from my late 74 260 2+2. The other is from my parts car and was going to be swapped in as rubbers are ok. As you can see different bends plus mounting holes on diff were different sizes, thought this was the worst problem but now this. The moustach bar I removed with bad rubbers ran behind the bracket which holds the rear suspension up also. The parts car ran in front. Checked my other cars and all seem to run in front.
This is a pic of the diff in my blue car.
This is the diff I removed from the parts car.
Is this a totally different diff or something because I thought if they were 180 or 200 all you had to do was reverse bar.
Need help, do I just order some new rubbers for other bar?
Your 74 260 has an R180 rear-end
Your Parts car has an R200 rear-end
The R200 is larger and has larger mounting bolts, so the holes in the mustache bar are larger.
You order new rubbers for your 74 if you want to keep the R180.
