Posted July 25, 200717 yr comment_216403 Can somebody please advise what size the inlet ports are on an L series head in particular N42 head if there are any differences across the range!?thanx sulio Link to comment https://www.classiczcars.com/forums/topic/25011-n42-head-inlet-diameter/ Share on other sites More sharing options...
August 2, 200717 yr comment_217304 Are you talking about where the manifold meets the head or valve seat area? Link to comment https://www.classiczcars.com/forums/topic/25011-n42-head-inlet-diameter/#findComment-217304 Share on other sites More sharing options...
August 2, 200717 yr comment_217306 Head is FIA Homogolated at 35mm Diameter. Link to comment https://www.classiczcars.com/forums/topic/25011-n42-head-inlet-diameter/#findComment-217306 Share on other sites More sharing options...
August 2, 200717 yr Author comment_217310 Where the manifold meets the head. Thanks guys. Link to comment https://www.classiczcars.com/forums/topic/25011-n42-head-inlet-diameter/#findComment-217310 Share on other sites More sharing options...
August 3, 200717 yr comment_217371 Mine all measured the same 34mm. Link to comment https://www.classiczcars.com/forums/topic/25011-n42-head-inlet-diameter/#findComment-217371 Share on other sites More sharing options...
