July 27, 200717 yr comment_216688 MSA wouldn't have brass bushings that I'm aware of. I never owned a Dodge, I just remember that it said that on the package. I did own a 71 Plymouth Duster 340 6 pak that I wish I had today. It's probably rarer than a sub 500 VIN 240Z. Link to comment https://www.classiczcars.com/forums/topic/25020-shifter-problem/?&page=2#findComment-216688 Share on other sites More sharing options...
July 27, 200717 yr comment_216690 How difficult is it to replace those bushings? I was going to ask the same question . My 79 shifter has felt a bit sloppy a of late. Link to comment https://www.classiczcars.com/forums/topic/25020-shifter-problem/?&page=2#findComment-216690 Share on other sites More sharing options...
July 27, 200717 yr comment_216692 Here is a link to the "Brass Bushing" replacement.http://atlanticz.ca/zclub/techtips/shifterbushing/index.html Link to comment https://www.classiczcars.com/forums/topic/25020-shifter-problem/?&page=2#findComment-216692 Share on other sites More sharing options...
July 27, 200717 yr comment_216696 Ebay has several shifter bushings for sale. Just search there for "240z shifter".The hardest part on changing the bushings is keeping track of the c-clip on the end of the cross pin that the bushings fit over. The clip wants to fly away when you pry it off unless you are very careful. Link to comment https://www.classiczcars.com/forums/topic/25020-shifter-problem/?&page=2#findComment-216696 Share on other sites More sharing options...
July 27, 200717 yr comment_216700 Why go eBay? There under 3 bucks at the dealer. 32855-H1010 Link to comment https://www.classiczcars.com/forums/topic/25020-shifter-problem/?&page=2#findComment-216700 Share on other sites More sharing options...
