Email logins are now active ×
Differential removal
PRSgodzilla
Might be best if you remove the diff. housing with the moustache bar still attached [assuming it is still in the car].
Once out of the car you can get a decent go at the retaining nuts.
They screw on to studs which screw into the rear cover.
If one of the nuts is stripped, just cut it down with a grinder until it falls away.
The studs can be renewed, but if you are clever enough you shouldn't damage it with the grinder:nervous:.
The Haynes manual calls them "differential rear mounting bolts" but they are really screw in studs with a nyloc nut.
