what is wrong with this dyno sheet??
justin260z
The date code would look strange to the average American, because we write the date month-day-year, and it would seem to indicate September 3, 2007. In fact however the rest of the world writes the date day-month-year, which shows that the dyno reading was taken on March 9, 2007.
Is that what you thought was weird?
I thought you all would be confused by the format of a non-u.s. dyno sheet. Thats why I thought it was wierd.
The top line is for the kw.... converted is about 103hp
The bottom line....... I have no clue how to convert that into tq. Maybe someone else knows.
The torque curve does not make sense to me. The peak (if you ignore the values near idle) seems to be around 2200. The scale is labeled N but as someone else pointed out it would normally be newton meters or Nm. 1 Nm = 0.737 lb-ft but there's no way a 103HP engine would put out 1622 lb-ft of torque. Hopefully a non-US person can explain it to those of us still using an antiquated system of measurement.
As far as the date format goes I deal with it all the time in software development. I think m-d-y and d-m-y are both silly. y-m-d makes the most sense. After all, you don't tell time in s:m:h or m:s:h ...
  • Who's Online   0 Members, 0 Anonymous, 496 Guests (See full list)
