71 240Z, all stock. I get no spark from the coil. I've changed out the points for a known good set, same with condensor. Using a test light, I have power at both sides of the coil. I changed it out for another, I believe to be good, not sure. With ignition on, points open, I have power to both sides of the coil. Where do I go from here? It's been a couple of days since I tried last, and I can't remember what I had with points closed. I want to be sure that everything is operating correctly to the coil before I condemn it.
Devin
https://www.classiczcars.com/forums/topic/25180-no-sparrk/
To anybody looking in the future, I got it figgered out. I was losing power between the negative side of the coil and the points. I made a jumper wire that ran from the coil to the condensor and had power to the points. Fired right up. I hope this can help somebody else.
Devin
https://www.classiczcars.com/forums/topic/25180-no-sparrk/#findComment-218155
