Posted August 13, 200717 yr comment_218345 Well i'm going through my system and I was wondering what the plug gap is fora 72 240Z. I read that it was .036 and i was wonderng if that was right.I have some Iridium IX sparkplugs. Thanks Link to comment https://www.classiczcars.com/forums/topic/25199-spark-plug-gap/ Share on other sites More sharing options...
August 13, 200717 yr comment_218350 .031-.035 seems to be the acceptd range for an L24 w/points. Since you already have those Iridium plugs, run em but next time I'd recommend the standard NGK BP 6ES. You'll get differing opinions but the majority would agree. Link to comment https://www.classiczcars.com/forums/topic/25199-spark-plug-gap/#findComment-218350 Share on other sites More sharing options...
August 13, 200717 yr comment_218351 Stephen is correct about the NGK plugs! Just about everyone with an L6 motor eventually discovers that the NGK BP 6ES just seems to work the best.Tom Link to comment https://www.classiczcars.com/forums/topic/25199-spark-plug-gap/#findComment-218351 Share on other sites More sharing options...
August 13, 200717 yr comment_218362 Since they are paid for, install and run your Iridium plugs for a hundred miles or so, then swap to the BP®6ES-betcha won't put the iridium in swap back-or buy them for the Z ever again!Will Link to comment https://www.classiczcars.com/forums/topic/25199-spark-plug-gap/#findComment-218362 Share on other sites More sharing options...
August 13, 200717 yr comment_218363 Everyone's right about the standard NGK plugs in a Z. Before you go regaping those iridium plugs though, DON'T!!!!! If you try to gap iridium plugs you will crack the ceramic. That tiny little iridium tip isn't strong enough to take the force of a plug gapper pressing the ground electrode out, it will give and crack the ceramic around it. Most of the iridiums usually have a warning on the box telling you not to regap the plugs. Link to comment https://www.classiczcars.com/forums/topic/25199-spark-plug-gap/#findComment-218363 Share on other sites More sharing options...
August 13, 200717 yr comment_218364 I third the recommendation to use only NGKs. I have my engine back from Rebello and am using B8ES (no P and no R), but this is a heavily modded L28. Link to comment https://www.classiczcars.com/forums/topic/25199-spark-plug-gap/#findComment-218364 Share on other sites More sharing options...
August 13, 200717 yr Author comment_218366 cool, thanks won't try to regap them. I'm trying to trouble shoot my engine seems to backfire through the carbs a little during the warm up stage. I have the carbs set at about 3.5 turns out. I thought maybe they where a little too lean. Link to comment https://www.classiczcars.com/forums/topic/25199-spark-plug-gap/#findComment-218366 Share on other sites More sharing options...
August 13, 200717 yr comment_218371 The carbs will run lean during warm up unless the choke is set. I would swap to the standard NGK plugs now and see if your lean backfire doesnt go away. Your money would be better spent on switching to a newer 280Z electronic distributor with E12-80 module and a hotter coil. The swap is quite easy and it will provide a better overall ignition system. Link to comment https://www.classiczcars.com/forums/topic/25199-spark-plug-gap/#findComment-218371 Share on other sites More sharing options...
August 13, 200717 yr comment_218376 The carbs will run lean during warm up unless the choke is set. I would swap to the standard NGK plugs now and see if your lean backfire doesnt go away. Your money would be better spent on switching to a newer 280Z electronic distributor with E12-80 module and a hotter coil. The swap is quite easy and it will provide a better overall ignition system.But if you do that swap you'll want to go to the NGK B6ES-11 and gap them at .039-.043. Link to comment https://www.classiczcars.com/forums/topic/25199-spark-plug-gap/#findComment-218376 Share on other sites More sharing options...
August 13, 200717 yr Author comment_218387 So the reg NGKs are fine, no need to get platinum NGKs ?? Link to comment https://www.classiczcars.com/forums/topic/25199-spark-plug-gap/#findComment-218387 Share on other sites More sharing options...
August 13, 200717 yr comment_218388 No, no need for the platinum, regular copper core NGKs really do work the best. Link to comment https://www.classiczcars.com/forums/topic/25199-spark-plug-gap/#findComment-218388 Share on other sites More sharing options...
August 13, 200717 yr comment_218391 But if you do that swap you'll want to go to the NGK B6ES-11 and gap them at .039-.043.I've found that NGK BPR6EY-11 (V-Power) also work great with the E12-80 ignition, and might be easier to find in some places. Link to comment https://www.classiczcars.com/forums/topic/25199-spark-plug-gap/#findComment-218391 Share on other sites More sharing options...
