Recently Browsing 0
I finally got the round top su's on this evening. I've plugged all the hoses to the extra stuff on the balance tube, for now. The pieces are intact. The egr is still present and hooked up. But since I removed its vacuum source, I don't think it will be opened.
I turned the key and it started running. It is popping gas out the carburetors a bit. But, I think this is expected for being completely unbalanced? So, I am feeling good and the rpm's start to rise to 4,000 with choke and 3,000 without. So, I attempted to adjust the ilde screw. It didn't seem to have an effect -- all the way in or all the way out.
Looking a little closer, I realized that the tab that should oppose the idle screw is about 1/4" away from the carburetor body with the screw all the way out!
The throttle linkage that goes from the balance tube to the carburetors is the same length. But, the angle between the ball joint to the pad appears to be something like 10 deg. difference (just guessing).
So, it looks like I will have to adjust the screw on the firewall linkage. Hopefully, I have enough extra room to make it work.
Are there any other places that I will be able to add slop? Should I try those first?
https://www.classiczcars.com/forums/topic/25220-round-top-conversion-linkage-geometry/Share on other sites
