Posted August 15, 200717 yr comment_218581 Hello Everyone. Have I got a new problem for all. My husband used to be a member- MDC75. He told me that if this happened to our Z car then I would be screwed. Well my worst fear has happened.I went to pull the hood latch on my 75 280 and the cable broke!!!Is there anyone that has had this happen to them & what was their solution?Thank you very much."Drive Fast- Take Chances"Stacey Pike- CornishEl Cajon, California1973 240 Z Series 4 Coupe1974 260 Z Coupe1975 280 Z Coupe1975 280 Z Coupe- For Sale Link to comment https://www.classiczcars.com/forums/topic/25221-check-this-out/ Share on other sites More sharing options...
August 15, 200717 yr comment_218584 A friend had this happen to him and he was able to get at the latch by unbolting the hood hinges . He then had someone hold the front of the hood up some and was able to trip the latch by crawling under from the front . I ran a length of stainless wire to the latch and into the area by the steering post. I had a cable brake on me but I just reached the wire and gave it a yank . Good luck with the hood latch. Maybe someone else has a better way of reaching the latch. Gary Link to comment https://www.classiczcars.com/forums/topic/25221-check-this-out/#findComment-218584 Share on other sites More sharing options...
August 15, 200717 yr comment_218610 When mine broke, I jacked the front driver's side up so I could get under the car and reached the latch with a screw driver and tripped it. Then installed a new one. That was last year and the first time I ever had one break. I've owned the car since the mid 70's. Link to comment https://www.classiczcars.com/forums/topic/25221-check-this-out/#findComment-218610 Share on other sites More sharing options...
