I was wondering if the 240z had a rear main seal. Is it 1 one piece or multiple piece?
I am trying to track down an oil leak thats around my oil pan gasket near the transmission. If it does, does someone know the part number?
https://www.classiczcars.com/forums/topic/25225-rear-main-seal/
There are two rear seals on the L24. There is the circular seal that goes around the crankshaft and the seal that goes in the block. If you have a rear seal leak, it is most likely the circular seal around the crankshaft.
