konig or panasports
-speed240z
Konig does make a 16" rewind. You can find it at Motorsport: http://www.thezstore.com/page/TZS/PROD/WWC001H/25-1151
Panasports are also on sale there as well: http://www.thezstore.com/page/TZS/PROD/PFW/25-1016
They are only 7" wide though... Not sure if you wanted to stick to the 8" + wheels or not...
I've been doing some research on this topic and Panasports are at least double the cost of Konig's. Konig's are good for standard drivers, but, Panasports are stronger and will hold up to hard cornering and racing conditions.
-- Mike
-- Mike
And the Panasports look better :laugh: ... plus they're made in Japan...
Seriously, I like both but prefer the look of the Panasports. Have you looked at Rota's? They make a wheel that looks much closer to the Panas. I think the Konigs look more like the Watanabes.
Nate
I guess that's why there are multiple choices. Because while I too like both, I prefer the Konigs. It's all personal.
One possible thought, the Konig center caps do have issues on 240Zs. But that's not normally a problem for the ZG look, as most people don't run the caps in that case.
Arne,there really isn't much of an issue with the centercaps. All I had to do was tap the hub centercap in a little. I've also been told that Nissan made two different size caps; one shorter and one taller. Who needs a taller cap anyways since all it does is collect more dust and dirt. The shorter one needs no tapping to make the caps fit. Here is my wheels with the cap in place.
I also prefer the Konigs mainly because of price and the fact that I'm not building a full blown racecar that would need really wide tires.
Art, when I click on your pic it says that image has errors and won't load. Would like to see a larger size image.
Thanks, G.D.
