Has anyone ever used Hurculiner as a sound deadener and a rust proofer? I am putting Second Skin in my 240Z to quiet things down and lesen the heat. Someone told me that Hurculiner on the floor pans and the rear deck with seconf skin on top work well together. I am just concerned about the Second Skin sticking properly to the rough Hurculiner. Any words of wisdom?
Brad
I applied Herculiner to the external surface of wheel wells, rear deck and floorboards after POR-15. Then the whole body was painted. I put SecondSkin's Damplifier on the passenger side of the floorboards along with some extra inside the doors and quarter panels. I doubt it will adhere well to a roughened surface, and if it did, the effect of the damplifier would be muted (ha!) since the surface area of contact between metal and dampenener would be decreased (less vibration -> heat transference) tha nif it was in contact with a smooth surface.
$0.02,
Steve
Thanks Steve,
I think I will just stick to the second skin on the interior of my Z. I guess I could put herculiner on the underside of the car. Good Idea. Thanks for the input.
Brad
