Posted August 28, 200717 yr comment_220018 I have a Nisondenso compressor from a Honda that I would like to use on my 72 240z. It fits where the smog pump mounts but must be mounted upside down so the fittings face away from the motor. Does anyone know if this compressor can be operated upside down without ruining the unit?Bob M Link to comment https://www.classiczcars.com/forums/topic/25353-ac-conversion-question/ Share on other sites More sharing options...
August 28, 200717 yr comment_220023 Fitting position is not an issue. The system is under pressure in operation so oil/freon are only traveling in one direction. Link to comment https://www.classiczcars.com/forums/topic/25353-ac-conversion-question/#findComment-220023 Share on other sites More sharing options...
