73 240z w/ l28
okay so my battery blew like a week ago due to a bad voltage regulator so i changed the battery and changed the voltage regulator and now it doesnt wanna start at all i bought a new coil new spark plugs and i got so tired dealing with points i got an electric dizzy but it has a e12 93 ignition module but i heard it will still work but not as good as the e12 80 so onward, so i installed this i check for spark and i get a nice blue spark from the coil and then i check the spark plugs to see if i get spark and i do and i crank it and it doesnt wanna start so i spray starting fluid in the crabs and nothing i really dont know what the problem is i hope its not an internal problem i really need help i dont like seeing my z undriven
https://www.classiczcars.com/forums/topic/25377-need-help/
i started investagating this more...i took out all my spark plugs and looked and saw that some spark plugs are really clean and dont show any signs of gas beeing blown in the cylinder and some do
https://www.classiczcars.com/forums/topic/25377-need-help/#findComment-220210
