Email logins are now active ×
z car frustration!!!!
FairladyZS30
Are your plugs wet? Mine seem to have some dampness to them, but it's more viscous, like oil...mind you, they aren't SOAKED, but lightly damp...I am certain I am not getting gas into the chamber....are you seeing something similar?
Also, how sensitive are 240s to plug gap? I would expect that even if off, you'd have some burbling or firing - I'm getting NOTHING....NADA. Spray the ether, it fires then dies...I know there's no gas getting there. As Steve suggested, I'll take a look at the fuel pump, I suspect that's the issue.
I don't have an answer, like I said before, but I don't think timing, spark plugs, distirbutor, etc. would have anything to do with it if the problem was created when you battery blew due to a bad regulator. It has to be somewhere in the starting or charging circuit. Fuses, fusible links, ignition relay, etc. Anything that could be damaged by a power spike or surge.
My assumption is based on the fact that nothing else has been changed since the battery blew. IF I'd ever been in the same situation, I would have followed the battery/regulator/alternator path in attempting to locate the problem. But with all the tinkering in other areas since that happened, who knows?
checked it all umm i cant really do the timing until i get the car started sop it would be very difficult
I's sure he meant 'static timing' i.e. distributor in the right relationship so that the rotor points to #1 plug wire when cylinder #1 it at TDC. The engine doesn't have to be running to check that. However, like I said before, if the car was running before the battery blew, and you haven't done anything to the timing since then, you can rule that out.
  • Who's Online   2 Members, 0 Anonymous, 571 Guests (See full list)
