Here are some pictures of the white clip on #237. The red color you see mixed in the white won't be in the final versions.
The clips are basically hand made, not an automated process that can crank out a large volume very quickly, so it will take some time to make them. It should be about a month for the initial batch, and I can order more later if needed. Only the earliest 1969/1970 Z cars need these, so the market for them is pretty small and I don't want to make and lot and then wind up with a bunch of extras. I am planning on selling a set of 2 clips for $20. That may sound like a lot, but I had to pay to have a mold made and then a per unit cost for each clip. I think shipping in the US should be $4 or less. d240zx2, kats, bobc, and cbudvet PM me if you are still interested based on that price, or if you want less.
-Mike
  • 2 years later...
Hello,
Early topics we have not seen here recently, have we?
Some of you may know this,differences of the early inspection lid.
I think there are 4 steps of the inspection lid(Early which have a plastic clip for retaining).
#1 The bigining(maybe prototype) do not have a L-shape tab which
is touched by the hood .Just have a rubber.
See the picture of the yellow Z.I believe this Z432 is PS30-00013.
You will notice there is no hood bumper,
also the bracket of the master vac hose is different.
#2 The second one has a L-shape tab but it is rivetted.
See the picture of the blue Z,this is HLS30-00476 11/1969
#3 The third one looks same which we usualy have seen.
But the L-shape tab,this separate piece is welded to the lid.
See the picture of the silver Z,this is PS30-00088 01/1970
#4 The fourth one is very common for us,this one piece (L-shape tab and lid together) finish is continued to the later production.
See the picture of the blue(clean) this is HLS30-02156 03/1970
Thank you,
kats
Which ones are these? I have a set of new ones......
Esprist
www.jdm-car-parts.com
That is the 4th type - pretty rare to have a NOS set.
Carl B.
Do you have pictures or description of the different types posted anywhere? I just might learn something here. 4 types?
That's exactly what Kats goes over in the first post.
  • 14 years later...
Just seeing this thread again, after it was re-linked to.
The original post has the images in PDF files which are hard to see at a glance.
RE: Attached is screenshots of all 4 types. I hope @kats doesn't mind me repeating it here, but this makes it easier for me to see each type.
Type 1, 432 prototype:
#1 The beginning(maybe prototype) do not have a L-shape tab which
Thank you Gavin! I appreciate your help!
Kats
