Posted September 5, 200717 yr comment_220635 I have noticed that TheZStore has 6 stages. I never looked into a performance camshaft to help get more out of my L24. Stage II does look the best for what I want. Though what I am looking for is what are the differences from the stock to Stage II cam? Does it increase HP, and generally how much? Or does it just basically shift and/or strengthen the power band?Man I need a high paying job. :hurt: Link to comment https://www.classiczcars.com/forums/topic/25429-performance-camshafts/ Share on other sites More sharing options...
September 5, 200717 yr comment_220642 more lift+duration = higher flow = higher HP potential.i have a stage 2.5 cam collecting surface rust if you're interested..... Link to comment https://www.classiczcars.com/forums/topic/25429-performance-camshafts/#findComment-220642 Share on other sites More sharing options...
September 5, 200717 yr comment_220657 The tips here include good info on cams.http://www.geocities.com/zgarage2001/engine.htmlIn brief, more lift helps power but there are mechanical limits on what is possible. More duration shifts the power band to higher RPMs but usually cuts the peak torque a bit.Stage I and stage II are the best matches for the RPM capabilities of an otherwise stock L24. Link to comment https://www.classiczcars.com/forums/topic/25429-performance-camshafts/#findComment-220657 Share on other sites More sharing options...
September 5, 200717 yr comment_220663 I have a new 480/274 stage 2 cam that I'll give ya for $75. That's half price from MSA.but like any stage 2 or higher cam, you'll need new lash pads and valve guides, or something like that.Dave. Link to comment https://www.classiczcars.com/forums/topic/25429-performance-camshafts/#findComment-220663 Share on other sites More sharing options...
September 5, 200717 yr comment_220666 Stage 2 is the second stage of wussiness, still a very small cam. Yeah, there are coil bind and lash pad and valve stem seal issues to deal with, but it's worth it in my opinion. Link to comment https://www.classiczcars.com/forums/topic/25429-performance-camshafts/#findComment-220666 Share on other sites More sharing options...
September 5, 200717 yr comment_220677 with two different guys having new cams and wanting to sell them, i have to ask why did you change your mind about installing them? too much trouble, or what? i looked at adding headers to mine, and was told that if i didn't change the cam, that the headers alone wouldn't do much. still learning here and i had to ask. Link to comment https://www.classiczcars.com/forums/topic/25429-performance-camshafts/#findComment-220677 Share on other sites More sharing options...
September 5, 200717 yr comment_220701 I did a job for a friend who owned a few Z's, he gave me the cam for a payment. He bought the cam for one of his Z's but wrecked the Z before installing the new parts that he bought.I already have a stage 2 cam, ceramic 6-into-1 header, 2 1/2" exhaust, Mallory Unilite Infra-red Distributor, MSD 6A ignition, Triple 40 DCOE Webers, and a couple other things. The cam really made a difference after the Header and ignition install. I LOVE the LOPEY sound and performance increase around 2500 to 5500 RPM. I get accused of having a V8 all the time while sitting at red lights.I accepted the Stage 2 cam as payment because I was gonna build another motor but the finances are shot after school shopping for 5 kids.Dave. Link to comment https://www.classiczcars.com/forums/topic/25429-performance-camshafts/#findComment-220701 Share on other sites More sharing options...
September 5, 200717 yr comment_220702 jmortensen said: Stage 2 is the second stage of wussiness, still a very small cam. Yeah, there are coil bind and lash pad and valve stem seal issues to deal with, but it's worth it in my opinion.Wait a minute, I'm confused. Does that mean "wussy is a good thing"? :stupid:Dave. Link to comment https://www.classiczcars.com/forums/topic/25429-performance-camshafts/#findComment-220702 Share on other sites More sharing options...
September 5, 200717 yr comment_220703 sleepyzzz said: with two different guys having new cams and wanting to sell them, i have to ask why did you change your mind about installing them? too much trouble, or what? i looked at adding headers to mine, and was told that if i didn't change the cam, that the headers alone wouldn't do much. still learning here and i had to ask.picked up the cam from ebay; waitied til i got a new head to install.buuuut.... picked up a head with a stage IV cam/schnieder valvetrain preinstalled, so the cam is just sitting there nowEDIT- i should also add that it's a reground stock by american cams, so high zinc oil isn't as necessary. and it's a solid cam Link to comment https://www.classiczcars.com/forums/topic/25429-performance-camshafts/#findComment-220703 Share on other sites More sharing options...
September 5, 200717 yr comment_220720 SORRY, I had the cam on Craigslist for 2 weeks and it just SOLD.Maybe next time,Dave. Link to comment https://www.classiczcars.com/forums/topic/25429-performance-camshafts/#findComment-220720 Share on other sites More sharing options...
September 5, 200717 yr comment_220721 HiI also have a stock engine, the MSA 6 into 1 header and nothing else more, them it`s all stock. I would like to increase a little bit the horsepower of my 240z too, so what the best cam I should buy to do it?how many HP, should I get with all that modifications?Thank YouFilipe A Link to comment https://www.classiczcars.com/forums/topic/25429-performance-camshafts/#findComment-220721 Share on other sites More sharing options...
December 30, 200717 yr comment_232406 I see on the Z store the full valve setup for a set price, doesn't matter which cam you buy its all the same price. I am tempted to get a Stage 6 cam (although it'll be a street car and maybe an eventual race car) but I can't justify 6k-8k RPM on the road. But if I go into vintage SCCA racing with the Z and bail out on my BMW 2002 I'd feel like a fool to buy a whole new valve setup jsut for a a crazier cam... I want my car to be as race ready as a road car can get (minus the exception for dirty playing on the exhaust and going straight pipes no muffler (probably a bad idea)). My reason behind this is the Corinthian Vintage Racing club wants their cars to be period correct and original. This makes it manageable for a teenager like me so I don't have to get into some major stuff like a big fancy gear box; they wouldn't allow because it wasn't made in '72, we can only run the 4 speeds or if you find the rare BRE 5 speed. Thats ok though, from what I've seen, the one Z at the track only had triple Mikuni's, headers, MSD, and probably higher comp. for race fuel and kept up with the deep pockets of the Porsche owners which had the 5 speed. And the Z guy was even running the wrong gearing for the track, and stock cam. :0 Sexy! Link to comment https://www.classiczcars.com/forums/topic/25429-performance-camshafts/#findComment-232406 Share on other sites More sharing options...
