jmortensen Posted January 2, 2008 Share #25 Posted January 2, 2008 If you really want to make power from your FI L engine, you'll need some sort of aftermarket ECU, whether that be Megasquirt or something else is up to you. Once you have that programmable FI, that cam you chose is going to be too small to make serious power. I'd suggest you stick with the stock cam and spend the money on the FI, then get a bigger cam. Link to comment Share on other sites More sharing options...
