Posted September 11, 200717 yr comment_221231 Got these new triples to replace the ones from the fire, not acting right called and got told " you cant get them set for factory idle of 850 rpm, there after market what did you expect, they have to have a much lower idle"Needless to say that didnt set right so called greg at motorsports and he said BS, we'll get an answer or replace them!!More updates to follow!!!!!!!! Link to comment https://www.classiczcars.com/forums/topic/25501-direct-from-redlineweber-tech-support/ Share on other sites More sharing options...
January 19, 200817 yr comment_234646 Well? Link to comment https://www.classiczcars.com/forums/topic/25501-direct-from-redlineweber-tech-support/#findComment-234646 Share on other sites More sharing options...
January 19, 200817 yr Author comment_234677 BullS**t, all done Link to comment https://www.classiczcars.com/forums/topic/25501-direct-from-redlineweber-tech-support/#findComment-234677 Share on other sites More sharing options...
January 19, 200817 yr comment_234686 TBK1 said: Got these new triples to replace the ones from the fire, not acting right called and got told " you cant get them set for factory idle of 850 rpm, there after market what did you expect, they have to have a much lower idle"Needless to say that didnt set right so called greg at motorsports and he said BS, we'll get an answer or replace them!!More updates to follow!!!!!!!!What was the final outcome to this matter?Am considering triple Webers, as well. Have myoriginal SU carbs from 72 240 on a L28 drive train. Link to comment https://www.classiczcars.com/forums/topic/25501-direct-from-redlineweber-tech-support/#findComment-234686 Share on other sites More sharing options...
January 20, 200817 yr Author comment_234825 The first set sent was defective, redline just tried the run around, but rich from msa took care of it! I would not go with webers again though!! Link to comment https://www.classiczcars.com/forums/topic/25501-direct-from-redlineweber-tech-support/#findComment-234825 Share on other sites More sharing options...
January 21, 200817 yr comment_234921 So why would you not go with Webers again?AM also considering SR40 swap Link to comment https://www.classiczcars.com/forums/topic/25501-direct-from-redlineweber-tech-support/#findComment-234921 Share on other sites More sharing options...
January 22, 200817 yr Author comment_234943 IMHO dont feel the Quality workmanship is there anymore Link to comment https://www.classiczcars.com/forums/topic/25501-direct-from-redlineweber-tech-support/#findComment-234943 Share on other sites More sharing options...
January 22, 200817 yr comment_234977 TBK1 said: The first set sent was defective, redline just tried the run around, but rich from msa took care of it! I would not go with webers again though!!So who's would you go with?Thanks, Link to comment https://www.classiczcars.com/forums/topic/25501-direct-from-redlineweber-tech-support/#findComment-234977 Share on other sites More sharing options...
January 22, 200817 yr comment_234983 RHChew said: So why would you not go with Webers again?AM also considering SR40 swapConsider 45's. 40's are too small even for an L24 IMO. Link to comment https://www.classiczcars.com/forums/topic/25501-direct-from-redlineweber-tech-support/#findComment-234983 Share on other sites More sharing options...
January 23, 200817 yr Author comment_235117 I think Mikuni's but havent any experience with them . Link to comment https://www.classiczcars.com/forums/topic/25501-direct-from-redlineweber-tech-support/#findComment-235117 Share on other sites More sharing options...
