Got these new triples to replace the ones from the fire, not acting right called and got told " you cant get them set for factory idle of 850 rpm, there after market what did you expect, they have to have a much lower idle"
Needless to say that didnt set right so called greg at motorsports and he said BS, we'll get an answer or replace them!!
More updates to follow!!!!!!!!
  • 4 months later...
What was the final outcome to this matter?
Am considering triple Webers, as well. Have myoriginal SU carbs from 72 240 on a L28 drive train.
  TBK1 said:
The first set sent was defective, redline just tried the run around, but rich from msa took care of it! I would not go with webers again though!!
So who's would you go with?
Thanks,
