Hey all, i have a quick question. I have just installed the replacement heater valve in my 280Z and I just need to know how much pressure the little thing is subject to. I have a pressure tester so I can make sure it doesnt leak, but I don't know how high i should pressureize it to. I searched around and saw something like 25lbs in one thread, but Id like a straight up answer if possible. Thanks to you all.
https://www.classiczcars.com/forums/topic/25533-radiator-pressure/
This is what the FSM says for the 77 280Z
SPECIFICATIONS
Engine ......................................................... L28
Radiator Type .................................................... Corrugated fin and tube
Cap relief pressure kdcm (psi) .............................................. 0.9(13)
Testing pressure kg/cm (psi) ........................ ;... ................. 1.6(23)
Water capacity
(including engine, liter (U.S. qt, Imp. qt) ...........................10.4 (11, 9 1/8) heater and reservoir tank)
25 psi is too much. 280 Master is correct with 13psi. If it leaks at 10, better think about using another one.
280~Master is correct but the testing pressure is 23 psi. 13 psi is the cap relier pressure.
