How to replace injectors.
dade280
I don't think that there would be any problem with that, though I am concerned with something you said: "they are really stretchy." FI lines are interwoven with mesh and wire.
They do not stretch.
At all.
Do the hoses say on them "For Fuel Injected Engines"?
If they don't, they have fuel line for the carbie engines.
I have had some luck in the past with similar problems by spraying on some PB Blaster. It won't harm the rubber, and is able to sneak between the hard and soft lines.
It's worth a try, and if you haven't gotten any PB Blaster, you might as well get some-the stuff is great.
  • Who's Online   0 Members, 0 Anonymous, 462 Guests (See full list)
