Email logins are now active ×
Installed Stainless brake hoses
TomoHawk
If you have Earl's hoses, you obviously have the non DOT Earl's Speed-Flex hoses.
That's confusing. Can you explain? I didn't see anything on those hoses to tell you which ones they were. Could be either type. Also, I was told that the ones I had were in the process of getting approved, so they are probably OK to use by now.
thxZ
I don't know how to tell them apart. I said that Earl's makes two kinds. You said your's weren't DOT approved. I looked into them about ten years ago but didn't buy them. The guy at the old 'Super Shops' told me about the two different kinds Earl's makes but I ended up buying stock hoses. Maybe you should do a search for Earl's Performance Speed-Flex Brake Lines or Earl's Performance Hyperfirm Brake Lines.
  • Who's Online   1 Member, 0 Anonymous, 196 Guests (See full list)
