Tension adjustments are inside, pop the glass out, and tightening the mechanism is easy-instructions for popping the glass are in my red dot restoration article in the technical articles forum.
Will
  • 11 years later...
38 minutes ago, zspert said:
Banzai Motorworks now offers an excellent reproduction Ever Wing interior mirror
Do you have a replacement mirror for the driver's door? '72 240, housing is good I need the beveled mirror.  Thanks for any reply.
Cliff, do you just need the glass mirror part?
Yes I do.  Just the glass.  I'll eventually go to a local glass supplier but they won't have the beveled edge.  I have a stick on 3" round one now so no rush until zcon 2019 when I'm coming for Zup's belt!
HAHa.  What about this Alabama game?  I'm enjoying this with some beers.  How are the snow drifts at Arrowhead Lake?  Its 60 degrees here.  Cliff
Alabama looks good tonight.  Oklahoma, not so much.  Snow is melting a bit but temperature is in the low 20s overnight.  I was going to suggest a glass shop, but sounds like you've checked into that already.  I did that with the Avanti outside mirror in the past.
Dennis
