Does anyone have a list of all the parts needed to build the 3.2 stoker?
I know you need the l28block, diesal maxima crank and 240sx 89mm pistons but what else do I need? I want to start collecting ALL the parts so I then can take it to the best machine shop I can find to install all the parts, balance etc.
Thanks Ketih
https://www.classiczcars.com/forums/topic/25661-32-stroker-parts-list/
Keith your at the wrong forum for that type of question. Anyway a few helpfull pointers for you to get your part collection started.
1. google 3.1 ltr datsun, be prepared to spend hours reading and learning.
2. Hybridz again a wealth of information.
good luck
rex
That combo you have listed will only make 3.1 or 3098cc more to the point. If you go to a 89.5mm bore you get 3133cc so that is more like 3.2 or with a 90mm bore 3168cc. The other option is a smaller bore and longer stroke = work to a LD28 to offset grind etc run at 85mm stroke not the stock LD28 83mm then you can get 3102cc at 88mm bore and 3173cc at 89mm and 3244cc at 90mm
