December 22, 200816 yr comment_269442 Ah, ok. I skimmed through a few pages of the thread without reading much, because there seemed to be a lot of 'filler'. Link to comment https://www.classiczcars.com/forums/topic/25674-i-have-to-find-these/?&page=10#findComment-269442 Share on other sites More sharing options...
December 22, 200816 yr comment_269465 Arne said: Wing, those look like 14x6 to me, plus I don't think AR ever made 15" four lug in that style. In fact, in four lug all I recall was 14x6, not even 14x7. How did you measure them? If you measured from the outer lips in both width and diameter to get 15x7, then they really are 14x6. The correct place to measure from is the bead seat area. I measured from the Rim lip on top to the lip on the other side and came up with 15 inches tall, but as far as width I did the same thing and got 7 inches. I'll resure with pics next time for all to see just to make either way on the width However I have to say for all I tried I can not find a makers kark on this rim but every little minut detail points to bieng the exact same design as the AR's . I know for a fact the Shelby Rims are different when it comes to the spokes curvature hoving compared this rim to my engine mechanics who has 2 Shelby rims. Not sure but if this is a dead set knock off of the AR Vectors then maybe this might have been in a 15x7 and a 15x6. Possible? but by who? And why is mine Blue, seems to be factory applied sblake01 said: I think the basic gist of this thread has been lost..........quite some time ago. mikewags said: Ah, ok. I skimmed through a few pages of the thread without reading much, because there seemed to be a lot of 'filler'. It may be off the original intention but if anyone is looking for a "Turbine" style rim then now they have a place to chose which one they want. Remember Darbji's delima when all the different versions got thrown at her ~Z~ Edited December 22, 200816 yr by WingZr0 Link to comment https://www.classiczcars.com/forums/topic/25674-i-have-to-find-these/?&page=10#findComment-269465 Share on other sites More sharing options...
December 22, 200816 yr comment_269471 WingZr0 said: I measured from the Rim lip on top to the lip on the other side and came up with 15 inches tall, but as far as width I did the same thing and got 7 inches. That's what I thought. That's not the correct way to measure a rim. Yours are 14x6s. The measuring point for both width and diameter is inside the lip where the base of the tire's bead seats. But as a rough guide you can measure as you did from the lips and then subtract 1" from each dimension. Link to comment https://www.classiczcars.com/forums/topic/25674-i-have-to-find-these/?&page=10#findComment-269471 Share on other sites More sharing options...
December 23, 200816 yr comment_269490 Arne said: That's what I thought. That's not the correct way to measure a rim. Yours are 14x6s. The measuring point for both width and diameter is inside the lip where the base of the tire's bead seats. But as a rough guide you can measure as you did from the lips and then subtract 1" from each dimension. Wise man, makes sense yo. But where can I find the makers mark if this indeed a AR? I looked everywhere and all I can find is the chalking my friend wrote that says it came off a '79 280ZX. At the very least thinking of keeping it and putting a round glass top on it and turnig it into a end table for my bed room or something. I just love that Light Blue ~Z~ Edited December 23, 200816 yr by WingZr0 Link to comment https://www.classiczcars.com/forums/topic/25674-i-have-to-find-these/?&page=10#findComment-269490 Share on other sites More sharing options...
December 23, 200816 yr comment_269501 That light blue was likely applied by a PO. If you make a table out of it, use lexan not glass unless it's really thick glass. (ask me how I know!) Edited December 23, 200816 yr by sblake01 Link to comment https://www.classiczcars.com/forums/topic/25674-i-have-to-find-these/?&page=10#findComment-269501 Share on other sites More sharing options...
December 23, 200816 yr comment_269524 sblake01 said: That light blue was likely applied by a PO. If you make a table out of it, use lexan not glass unless it's really thick glass. (ask me how I know!) How you know? Link to comment https://www.classiczcars.com/forums/topic/25674-i-have-to-find-these/?&page=10#findComment-269524 Share on other sites More sharing options...
December 23, 200816 yr comment_269526 WingZr0 said: How you know?You want a picture of the scar? Link to comment https://www.classiczcars.com/forums/topic/25674-i-have-to-find-these/?&page=10#findComment-269526 Share on other sites More sharing options...
December 23, 200816 yr comment_269535 sblake01 said: You want a picture of the scar? Depends on where and WHAT you doing Link to comment https://www.classiczcars.com/forums/topic/25674-i-have-to-find-these/?&page=10#findComment-269535 Share on other sites More sharing options...
