Posted October 4, 200717 yr comment_223505 How Do you put one of your pictures next to your name right here <---------------------------------- Link to comment https://www.classiczcars.com/forums/topic/25746-how-do-you/ Share on other sites More sharing options...
October 4, 200717 yr comment_223507 Go to the User CP item on the menu list on the left (under where it should say "Welcome Kcoke) click, that takes you to your Cotrol Panel, chose edit avatar from that list and chose a photo by brosing your drive where you have the picture you want to show stored. There are probably size limitations so you may have to reduce the size of the image if it says it is too big. Link to comment https://www.classiczcars.com/forums/topic/25746-how-do-you/#findComment-223507 Share on other sites More sharing options...
October 4, 200717 yr Author comment_223509 Got it thanks! Link to comment https://www.classiczcars.com/forums/topic/25746-how-do-you/#findComment-223509 Share on other sites More sharing options...
