Go to the User CP item on the menu list on the left (under where it should say "Welcome Kcoke) click, that takes you to your Cotrol Panel, chose edit avatar from that list and chose a photo by brosing your drive where you have the picture you want to show stored. There are probably size limitations so you may have to reduce the size of the image if it says it is too big.
