I need to try and locate the part numbers for Nissan for the "Tie Rod Assembly" that is the Tie Rod and also the Inner Tie Rod for a 1975 280z (north american model) ... the tie rod bolts on mine are seize and I have to change the tie rod boots for the car to pass inspection. Thank you for the help.
48510-E8700 for the right side (Assy Rod Side RH)
46630-E8700 for the left side (Assy Rod Side LH)
Courtesy Nissan is selling them for $135.59 @ piece on their website CourtesyParts.com. Nissan of Gastonia is listing them at $115.35 @ piece at BuyNissanParts.com.
