Profile says a '78 280Z.
Do you mean the stub axle? No threads to strip on the half-shaft. If it's the stub axle you need, both sides are the same. You'll need one from a 280Z, the spline count on the 240Z are different.
Last I checked, new ones were still available from Nissan, but they aren't cheap...
