Posted October 13, 200717 yr comment_224337 I have taken the whole front of my engine off & need better photos of that area. Where can I find this. I have a 75 280 Z. Thanx, Stacey Link to comment https://www.classiczcars.com/forums/topic/25839-loose-timing-chain/ Share on other sites More sharing options...
October 13, 200717 yr comment_224338 A Chilton manual should help. Also you should try to find an original factory service manual. They're hard to find, though.If you have a shop locally that specializes in Zs, stop by and take a look at what they may be working on. That will help, too.Frank Link to comment https://www.classiczcars.com/forums/topic/25839-loose-timing-chain/#findComment-224338 Share on other sites More sharing options...
October 13, 200717 yr comment_224340 carfiche.com has Factory Service Manuals online.I just downloaded the 76 280z one.Vince Link to comment https://www.classiczcars.com/forums/topic/25839-loose-timing-chain/#findComment-224340 Share on other sites More sharing options...
October 13, 200717 yr comment_224360 If you want your own here is a link to the manual on disk;http://www.courtesyparts.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=CP&Product_Code=CD28075A Link to comment https://www.classiczcars.com/forums/topic/25839-loose-timing-chain/#findComment-224360 Share on other sites More sharing options...
October 13, 200717 yr comment_224417 I just bought a complete cam kit (Cloyes) for a 280Z for $126. The kit comes with both guides, the tensioner, both gears and a new chain. Sounds like this is what you need. Link to comment https://www.classiczcars.com/forums/topic/25839-loose-timing-chain/#findComment-224417 Share on other sites More sharing options...
October 13, 200717 yr comment_224450 Any idea how many miles are on the chain? There are 3 adjustment positions on the camshaft sprocket itself that can be used to compensate for chain stretch. You may not need to buy anything other than new gaskets for when you put it back together. All of the service manuals (factory and after market) cover this. Link to comment https://www.classiczcars.com/forums/topic/25839-loose-timing-chain/#findComment-224450 Share on other sites More sharing options...
October 13, 200717 yr comment_224467 I'd recommend replacing the bolts and use lots of thread lubricant. I've seen Z's with broken tensioners which causes timing slop. Link to comment https://www.classiczcars.com/forums/topic/25839-loose-timing-chain/#findComment-224467 Share on other sites More sharing options...
November 8, 200717 yr comment_227809 Those three holes on the cam sprocket is not to compensate for chain stretch, when a chain stretches the crank angle and cam angle veer further apart, which is not good at all, 0 deg crank angle should be 0 degree cam angle. Every two rotations of crank delivers one rotation of cam, with a degree of differential between the two it will only give incorrect cam to crank geometry, hence the reason for the two bright links on the original Nissan Timing chain, these two bright links are to be positioned on the dots of the cam gear and the crankshaft's distributor drive gear. The three holes on the cam sprocket is to accomodate any cam degree advance neccessary at time of installation of camshaft this will be determined by the cam designer/manufacturer...... I will assist anyway I can.... forward onwards Z lovers Link to comment https://www.classiczcars.com/forums/topic/25839-loose-timing-chain/#findComment-227809 Share on other sites More sharing options...
November 8, 200717 yr comment_227815 Quote There are 3 adjustment positions on the camshaft sprocket itself that can be used to compensate for chain stretch.Though that is not the experess purpose of the adjustment positions, it is stated as such in the service manuals. Randy, are you trying to impress us with your knowlege of the L series engine? We're not talking about installing a performance cam in this instance. Link to comment https://www.classiczcars.com/forums/topic/25839-loose-timing-chain/#findComment-227815 Share on other sites More sharing options...
November 8, 200717 yr comment_227822 I agree. I just intalled a rebuilt head with my new shortblock. I have a stroker engine. I need more power at the upper end. I set the gear in the number #1 hole to retard the carshaft. It is a stock cam so I will not bother to "time" it. If it does not work, I can always set the cam gear at #2 or #3 hole until I have the power where I want it. Datsun engines are very easy to change timing. Now with a high lift cam with a lot of overlap, I use an adjustable timing gear. I will break out the degree wheel, the gauges and the specs and spend a couple of hours playing with my cam timing. See why I use stock cams and stock settings? Funny how you get lazy when you reach 65! Link to comment https://www.classiczcars.com/forums/topic/25839-loose-timing-chain/#findComment-227822 Share on other sites More sharing options...
November 8, 200717 yr comment_227827 sblake01 said: Though that is not the experess purpose of the adjustment positions, it is stated as such in the service manuals.I clearly got the information from the service manual. Sorry for spreading bad information. Link to comment https://www.classiczcars.com/forums/topic/25839-loose-timing-chain/#findComment-227827 Share on other sites More sharing options...
November 8, 200717 yr comment_227837 Mike, I was agreeing with you. I worded that post wrong. I was actually resonding to RandyN's comment and using your statement to back up my response. RandyN said: Those three holes on the cam sprocket is not to compensate for chain stretch,I meant that it does state in the manual that the adjustment holes can be used to compensate for chain wear. It's just not clear the way I worded it. Link to comment https://www.classiczcars.com/forums/topic/25839-loose-timing-chain/#findComment-227837 Share on other sites More sharing options...
