Starting Issue.
Corrao
you mentioned that the fuel before the injectors is ok..
did you check weather the injectors ARE injecting??
sometimes they get jammed and they open if you give them direct pulse of 12V (works like jerking them and the start opening and closing normaly again) but don't keep the voltage longer than a pulse..
or just check the exhaust after cranking for few seconds if there is a fuel smell or not, if not that means that you are not having fuel going in and your sparks are ok.
since it was running before, I assume that no one missed up with the firing order.
mind callin me heh... would be easier to talk and work then run in the house to check for updates 7605081653
I sent you a PM (private measage) with my phone number.
The place I'm at now don't have long distance :mad:
Check you private measage link in the box were it says Welcome Corrao
near the upper portion of the screen.
~Z~
ok ... well the tubes running to the injectors are stiff how would i go about checkin to see if there spraying without having to take the whole fuel rail off.. i dont wanna cut tubes just to get it off cause then it wont be hooked up for me to see if it works :( who called me BTW was it you wing? both 530 area codes but u said u cant call out so..
Thats was me ^_^
My cusine walked in with her cell phone.
you can reach me still as she'll be here for awhile Yo!
My repair manual says your ignition coil could be shot.
Theplug wire in center of the Dizzy runs to this.
Might need replacing or you ignition timing and/or valve timing may be off.
Did you try all 6 possible starting point as sugested?
~Z~
