Paint scheme Zero
dade280
I was reading an article on Z's the other day that said the guys who helped make the Zero fighter in WWII also helped on Z's. Then i was reading some other article and it said the people that worked at Prince Motor Company worked on the Zero fighters. So at around 4am i came up with this. Would look crazy with some Works Equip wheels. Dont flame me for thinking up crazy paint jobs :finger:
Hehehe civics are more like target practice. Tweaked design a little bit, Z is too big and im not sure i want it there but i think the texture on it and the 280 looks good.
Nothing against the new design but I like the Wall Tagging 280 better,
you should do a version of that with a smaller Z logo above it centered
between the kills and the '80 tagging.
Or anotha idea for the first design is put the Z log on the Tail "rear fender"
between the back wheel well and the end of the body centered under
the gas tank door.
Or Lastly center the Z logo on the 45 degree angle between
the back wheel well and the gas tank door. :)
The last 2 ideas would at least give you a Tail Fin insignia :rambo:
~Z~
