Anyone know if the air cleaner "wing bolts" that attach the air cleaner to the carbs are still available? I'm swapping out my individual air cleaners for the factory setup. The air box I have came with the car but one of the bolts is missing. Thanks.
https://www.classiczcars.com/forums/topic/25912-72-air-cleaner-fasteners/
They're on the Z car microfiche cd. Then I run them through the search on NissanParts.cc to see if they're still valid. That doesn't mean that they're still available just that they're still in the system.
If you're talking about the 2 wingnut style bolts that hold the lid of the aircleaner box to the carbs, I probably have a couple sitting around the shop.
PM me your mailing address and I'll send it to ya. You decide if and how much ya wanna pay for it. Do you also need the adaptor nut that bolts the box to the carb, and accepts the wing bolt?
Dave.
They are no longer available from Nissan. If you are lucky you might find some at a dealer in a dusty old bin or take the offer to get them used from someone else.
Thanks Dave... but I found the other bolt in a box of parts that I got with the car.
Stephen,
I ordered the CD, thanks for the info. One more request. Do you have a part number for the gasket/seal between the airbox cover and the lid? Mine is brittle.
Stephen,
Here's the pages that cover those. Hopefully they came through clear enough:
