Posted October 20, 200717 yr comment_225523 My engine combination is ~N42 Block~N47 Head~Japan N47 Intake Manifold~33306A Exhaust Manifoldon a Fuel Injected 1977 280Z 4 speedOK, Some of you may know I made mention of my #6 FI Port being clogged a.k.a. not getting gas.Well today I decided, since I'm saving money for a clutch, to take off the back half of the fuel rail connecting the number 4, 5 and 6 FI Ports and see if I can can unclog #6 with Chem Tool which I think is called B-12 (Some sort of adhesive, PCV, carb cleaner)After taking off the rail I could see down into the 4, 5 and 6 ports and saw that number 6 had some blackish wool like stuff in it.Looking at #4 and 5 on the other hand I saw only small amounts of the black stuff wear the top of port mets the cylinder head wall which had what appear to be razor slits.On the bottom of the port tube is a Silver Ring Arch shape on the cylinder head wall with a hole underneath it (kind of like a bridge) that I assume is wear the Air intake is but at the same time allows gas from the Fuel Injector to fall in and mix with the air in the combustion chamber.Ok, thats what numbers 4 and 5 look like but in the number 6 FI port, after removing the the blackish wool stuff, all I saw was the right half of the Silver Ring Arch hiding behind the bottom left hand side of the FI Port tube leaving no place for the gas to go except straight into the side of the cylinder head wall and the razor slit things :hurt: !Taking off the first half of the fuel rail to look at numbers 1, 2 and 3 FI Ports I can see they all appeared same as 4 and 5 with a hole under the Silver Ring for gas from the injectors to go through.I assume this is how they're supposed to look?Each hole under the Silver Ring Arches get slighty off bottom center of the FI Port the further you go away from the middle of the cylinder head.I sprayed the Chem Tool in all ports and #6 didn't drain down into any hole only staying inside the port making a puddle of liquid.Letting it sit for a mintute or two I loosend up a couple of Intake mounting studs and the Chem Tool drained but I believe it was only between the Intake gasket and cylidner head wall. The Chem Tool still drains even after tighten back the mountin studs :dead:All the Intake manifold studs line up correctly and go in and out with ease so what is causing my Fuel Injector Port / Ports to not align?Thaynx for ANY help at all on this.~Z~ Link to comment https://www.classiczcars.com/forums/topic/25947-fuel-injection-port-blocked-solid/ Share on other sites More sharing options...
October 21, 200717 yr comment_225555 I'm having a little trouble with your terminology. Such as, "cylinder head wall", "razor slit things", "Silver Ring Arch", etc. If your injection ports are clogged, the best thing you can do it remove the intake manifold and clean them, or have someone do it. Since you "loosend up a couple of Intake mounting studs", as you said, I hope you realize that you're now going to have to remove both the intake and exhaust mainfolds and replace that gasket evidenced by the fact that it "still drains even after tighten back the mountin studs". That's telling you that the seal has been compromised. I doubt that your ports don't line up, they just need to be cleaned. Hope you haven't gotten in over your head on this one. Link to comment https://www.classiczcars.com/forums/topic/25947-fuel-injection-port-blocked-solid/#findComment-225555 Share on other sites More sharing options...
October 21, 200717 yr Author comment_225560 I'm loading a JPEG drawing now. Give me a sec. Link to comment https://www.classiczcars.com/forums/topic/25947-fuel-injection-port-blocked-solid/#findComment-225560 Share on other sites More sharing options...
October 21, 200717 yr Author comment_225564 Hope you haven't gotten in over your head on this one. Nope I do relize I need a new gasket now. This hole is on the outside of the cylinder head right at the same place each Intake Manifold tube connects, i.e. where the Fuel Injectors sit above. All the FI Ports has this hole at the bottom of the port except for #6 . In the Drawing below, Black is the inner walls of the Fi Port as your looking down into it. Dark Grey is the outside of the Cylinder Head on the drivers side. White boxes are the Razor Slit looking things. Light Silver is the Siver Ring Arches Blue is the hole under the arch falling into the combustion chamber. Drawning of port at this link.... http://i170.photobucket.com/albums/u280/Wingzr0/1%20pics/FIPort.jpg?t=1192979781 Ports 1 through 5 look like this but slightly off centered while on the number 6 port all you see is the top right half of the Silver Ring sitting on the bottom left of the port with the hole out of view trap between the Intake Manifold flange and the gasket. I'm just assuming this is where the hole leads to, but I am ready to go that extra mile and take this N47 head of the engine block and go through this thing up and down if need be. I like to know what I'm dealing with first so as not repeat a possible problem I may or may not have Just don't understand why all ports look the same when one does not. I'm I missing something here on this? I'l take pics of the ports latter today if that helps and hopefully get them uploaded, if not tommorow morning. ~Z~ Link to comment https://www.classiczcars.com/forums/topic/25947-fuel-injection-port-blocked-solid/#findComment-225564 Share on other sites More sharing options...
October 21, 200717 yr Author comment_225565 Oh yeah, BTW the gasket is made out of rubber if that means anything.As well as the Valve Cover and Cylender Head to Engine Block gaskets. Link to comment https://www.classiczcars.com/forums/topic/25947-fuel-injection-port-blocked-solid/#findComment-225565 Share on other sites More sharing options...
October 24, 200717 yr Author comment_225964 Going out to take pictures of all 6 FI Ports rIght now and get the pictures up later today, so hopefully this will help in my description. Taking off the Intake and Exhaust Manifolds while I'm at it so hopefully I can see whats really going on behind the drama. Yakin off the Cylinder Head tommorow if need be and check the pistions for this "Carbon Build Up" I've been hearing about and clean it. So Big day off work for me today and tommorow and lots of time with my Z and phone calls to MSA WOO HOOOOO !, I LOVE THE SMELL OF OIL AND GASOLINE ~Z~ Link to comment https://www.classiczcars.com/forums/topic/25947-fuel-injection-port-blocked-solid/#findComment-225964 Share on other sites More sharing options...
October 25, 200717 yr Author comment_226074 OK, Heres what #6 FI port looks like... and here is #3. As you can the Silver Ring Arch I was reffering to is the band of silver arching ocer the hole at the bottom of the port. I'm assuming it leads to the combustion chamber. Ports 1, 2, ,4 and 5 look the same as number 3 does but with the hole on the bottom slightly off center more and more. The Silver Arch on Port #6 however is completly blocked off and the hole is somehow between the intake manifold and the gasket on side of the cylinder head which holds the cam and stuff. Is there something wrong here and what are those rectangler slits above the hole? More photos of different enlargments and angles here. http://s170.photobucket.com/albums/u280/Wingzr0/1%20pics/ P.S. I had to roll the car into the angle of the sunlight to get these photos right. :rambo: Oh yes, how do I get the tube going from the exhaust manifold upto the EGR Valve on the intake manifold? The bolts holding the tube together seem to be stuck or something, other than that I got everything disconnected to take those manifolds off execpt for those 1 to 3 bolts. ~Z~ Link to comment https://www.classiczcars.com/forums/topic/25947-fuel-injection-port-blocked-solid/#findComment-226074 Share on other sites More sharing options...
October 25, 200717 yr comment_226090 i'd use LOTS of pb blaster on the stuck ones. I used that stuff today to replace my master cylinder and take off a section of my exhaust. AWESOME stuff.as for the crap plugging your intake. it looks like the inside of a freakin radiator o_O Link to comment https://www.classiczcars.com/forums/topic/25947-fuel-injection-port-blocked-solid/#findComment-226090 Share on other sites More sharing options...
October 25, 200717 yr comment_226098 I reckon your manifold gasket is one designed for carby intake. EFI heads have an extra small notch cut out of their gasket to allow for you injector. The right gasket looks like it would make a hell of a difference. Don't know how your car would have ran like this. Swap the gasket and scare yourself with the change it makes.Congratulations, you've just gained an extra 2 cylinders my friend. Link to comment https://www.classiczcars.com/forums/topic/25947-fuel-injection-port-blocked-solid/#findComment-226098 Share on other sites More sharing options...
October 25, 200717 yr Author comment_226114 i'd use LOTS of pb blaster on the stuck ones. I used that stuff today to replace my master cylinder and take off a section of my exhaust. AWESOME stuff.as for the crap plugging your intake. it looks like the inside of a freakin radiator o_O Thyanx , WD40 wasn't gettin it. Radiator ? I reckon your manifold gasket is one designed for carby intake. EFI heads have an extra small notch cut out of their gasket to allow for you injector. The right gasket looks like it would make a hell of a difference. Don't know how your car would have ran like this. Swap the gasket and scare yourself with the change it makes.Congratulations, you've just gained an extra 2 cylinders my friend. Thyanx for that info, I'll get the ordering that gasket from MSA today I'd rather be scared the right way then the WRONG WAY Is the Notch and Squar Slits a part of the gasket itself? Reason I ask is I'm hoping there not part of the Cylinder Head wall cause that would :hurt:. To answer your question she ran on 5 cylinders but the idle would die untill after letting it run for 10 or 15 minutes then it would hold (After setting the idle screw at 1,100 RPM :pirate:) Tach would dorp like a rock once, twice then three times in a row when going from dead stop neutral into 1st gear under load causing me to get on the clutch so the RPM's would clime by taking the load off the engine. Always has the same pattern though, once twice then three times with the Tach, sometimes only twice in row . However if I give her just a little bit of gas peddle the RPM would dip from 1,100 to about 800 or 500 then raise back up and drive like normal. Problem would dissapate some after driving awhile but if I didn't watch it the Tach could just suddenly drop all the way to zero RPM's locking the engine and car to a dead stop in 1st gear as oppposed to neutral or on the clutch where I would coast. Needless to say 2 or 3 times stalling like that helped Kill my clutch disc right there over time. And thats not counting any the PO's and what they did Yeah, so she ran like a Mac Truck with heart problems :cheeky: Still lots of power though for a 5 banger :cheeky: ~Z~ Link to comment https://www.classiczcars.com/forums/topic/25947-fuel-injection-port-blocked-solid/#findComment-226114 Share on other sites More sharing options...
October 25, 200717 yr Author comment_226118 Just a correction for archive reasons my Exhaust Manifold markings reads~3330A With no number 6 on it. Link to comment https://www.classiczcars.com/forums/topic/25947-fuel-injection-port-blocked-solid/#findComment-226118 Share on other sites More sharing options...
October 25, 200717 yr Author comment_226124 Thyanx Guys! I ordered the New correct 1977 Intake/Exhaust gaket from MSA and a Water Temperture Sensor along with some other parts. Should arrive Tuesday or Wedsneday and I'll let ya know how it turns out. Thyanx again ~Z~ Link to comment https://www.classiczcars.com/forums/topic/25947-fuel-injection-port-blocked-solid/#findComment-226124 Share on other sites More sharing options...
