Hey all,
I used to own a blue 2+2 280Z and then sold it and now I am back with a green 75 280Z. Currently I am working on getting the interior redone. So the interior is pretty much stripped. I am currently removing the tar (using the dry ice method and its coming along well) and getting a small rust spot fixed. Here are some pictures and I have some questions. thx in advance.
1)Regarding the rust spot in picture (behind the passenger side seat) in picture 4&5 - how much do you guys think it cost for it to be properly repair? 75-150 bucks?
Picture 1 & 2: My green machine
<a href="http://img90.imageshack.us/my.php?image=img0813ti7.jpg" target="_blank"><img src="http://img90.imageshack.us/img90/6696/img0813ti7.th.jpg" border="0" alt="Free Image Hosting at www.ImageShack.us" /></a>
<a href="http://img155.imageshack.us/my.php?image=img0823bh1.jpg" target="_blank"><img src="http://img155.imageshack.us/img155/2071/img0823bh1.th.jpg" border="0" alt="Free Image Hosting at www.ImageShack.us" /></a>
Picture 3: Interior being stripped:
<a href="http://img90.imageshack.us/my.php?image=img0782fy8.jpg" target="_blank"><img src="http://img90.imageshack.us/img90/1034/img0782fy8.th.jpg" border="0" alt="Free Image Hosting at www.ImageShack.us" /></a>
Picture 4&5:
<a href="http://img142.imageshack.us/my.php?image=img0807te9.jpg" target="_blank"><img src="http://img142.imageshack.us/img142/9233/img0807te9.th.jpg" border="0" alt="Free Image Hosting at www.ImageShack.us" /></a>
<a href="http://img149.imageshack.us/my.php?image=img0790xb1.jpg" target="_blank"><img src="http://img149.imageshack.us/img149/6527/img0790xb1.th.jpg" border="0" alt="Free Image Hosting at www.ImageShack.us" /></a>
https://www.classiczcars.com/forums/topic/25951-75-280z-project/
that isn't that big of a hole, I would suggest you go the strip to bare metal ... cut out the rot area, then either weld up with a small patch (get a buddy to do it if you can't) or use some mess and proper body filler to plug up the hole and seal it, See these links:
http://www.por15.com/prodinfo.asp?number=VC&dept=13
http://www.por15.com/prodinfo.asp?grp=RG&dept=10
I used these to eliminate my antenna hole on my 280z ...
... be sure to cover the bottom of the area with a good sealant. I used a roll on truck bed liner over my Por-15's bottom to repair the holes I had.
The job is half a day and will cost you a lot less in money and time than taking it to someone else.
  • 3 weeks later...
