Posted October 21, 200717 yr comment_225570 My car hals been leaking some kind of fluid on the inside of my car for a while now, and I thought it was power steering fluid, and I thought I had fixed it with some stop-leak fluid. But it is still leaking. And I just caught it dripping, and its bright green. Its leaking under the dash on the passengers side. How can I fix this? Link to comment https://www.classiczcars.com/forums/topic/25954-leaking-trans-fluid/ Share on other sites More sharing options...
October 21, 200717 yr comment_225571 did it smell like antifreeze? i am guessing the heater core or hoses that are attached to it. good luck with the fix. i will be dealing with that myself pretty soon. Link to comment https://www.classiczcars.com/forums/topic/25954-leaking-trans-fluid/#findComment-225571 Share on other sites More sharing options...
October 21, 200717 yr comment_225576 Leaking green on the passenger front floor is a leak coming from something in the heater core area (that green is antifreeze), more than likely one of the hoses where it attaches to the hot/cold temp valve, or the valve itself. I would recommend refurbishing everything in this area if/when the repair is made, such as replacing both hoses, valve, and getting the heater core checked out for leaks, etc. Link to comment https://www.classiczcars.com/forums/topic/25954-leaking-trans-fluid/#findComment-225576 Share on other sites More sharing options...
October 21, 200717 yr comment_225579 what would a transmission fluid do under the dash??are you sure that it is transission fluid?perhaps it is just an antifreeze as Dogma said.I've not experienced oil lines under the dash area..when the car is cold, open the radiator cap and compare the color of the fluid inside with the dripping fluid's color.. or at least you'll notice a lower level in the first place. Link to comment https://www.classiczcars.com/forums/topic/25954-leaking-trans-fluid/#findComment-225579 Share on other sites More sharing options...
October 21, 200717 yr comment_225580 Mohamed--It's NOT transmission fluid. This fluid that has been found is from the cooling system, the green caused by anti-freeze. Link to comment https://www.classiczcars.com/forums/topic/25954-leaking-trans-fluid/#findComment-225580 Share on other sites More sharing options...
October 21, 200717 yr comment_225589 dogma, I know that you are sure that it is not a transmission fluid, read the post carefully and you'll find out that I was supporting you oto confirm that it is an antifreeze.I was replying to him..cheers. Link to comment https://www.classiczcars.com/forums/topic/25954-leaking-trans-fluid/#findComment-225589 Share on other sites More sharing options...
October 23, 200717 yr Author comment_225867 Yes, its antifreeze. I am not exactally car savvy . Thank you for the help! I was afraid I was going to have some terrible problems to fix... I figured it was some kind of hose, but im glad its not too serious. Link to comment https://www.classiczcars.com/forums/topic/25954-leaking-trans-fluid/#findComment-225867 Share on other sites More sharing options...
October 23, 200717 yr comment_225876 Where in CT are you? Not too many of us up here. Link to comment https://www.classiczcars.com/forums/topic/25954-leaking-trans-fluid/#findComment-225876 Share on other sites More sharing options...
