November 10, 200717 yr Author comment_228034 i have a two years before i get my permit so i should have plenty of time and thanks for the advice the only problem is the fsm is for a 76' which i think is a bit different than the 75' but i think it will work also what part of Minnesota are you from? i was born in mankato and all my relatives live in fairmont,i was just wondering Link to comment https://www.classiczcars.com/forums/topic/26113-1975-datsun-280z-22-wont-start/?&page=2#findComment-228034 Share on other sites More sharing options...
November 11, 200717 yr comment_228151 i have a two years before i get my permit so i should have plenty of time Yeah I guess you do have time Didn't realize you were that yung The 1976 FSM will suffice for your 75 280Z. Really no differences between the two. I'm in Southern Minnesota (Cottage Grove/Woodbury area) Had to put my beautiful Z away for her winters nap about a few weeks ago. Link to comment https://www.classiczcars.com/forums/topic/26113-1975-datsun-280z-22-wont-start/?&page=2#findComment-228151 Share on other sites More sharing options...
November 11, 200717 yr comment_228192 Try this.1. Pull the black cover off the AFM2. Turn the ignition to on3. Inside the AFM rotate flap mechanismDo you hear the fuel pump turn on?Also check to see how the bypass starter button was hooked up. 1. Disconnect the solinoid (usually a small yellow wire) starter wire. 2. Turn the ignition to on3. Press your ignition start buttonWhile pressing the button do you hear the fuel pump turn on?The AFM has a safety circuit to shut off the fuel pump when the motor stops sucking in air. Durring starting, power is direct to the fuel pump. Once the motor starts, the AFM completes the circuit to the fuel pump. Link to comment https://www.classiczcars.com/forums/topic/26113-1975-datsun-280z-22-wont-start/?&page=2#findComment-228192 Share on other sites More sharing options...
November 11, 200717 yr Author comment_228240 the fuel pump turned on both times Link to comment https://www.classiczcars.com/forums/topic/26113-1975-datsun-280z-22-wont-start/?&page=2#findComment-228240 Share on other sites More sharing options...
November 11, 200717 yr Author comment_228241 what are the screws on the AFM for the ones toward the bottom always wondered what they were for Link to comment https://www.classiczcars.com/forums/topic/26113-1975-datsun-280z-22-wont-start/?&page=2#findComment-228241 Share on other sites More sharing options...
November 11, 200717 yr Author comment_228243 its puzzling when i try to start it it won't start and the plugs will be dry no matter if press the gas or not but i know the gas gets to the injectors and the injectors are brand new but still the plugs don't get wet so i don't know if the connectors are bad or what Link to comment https://www.classiczcars.com/forums/topic/26113-1975-datsun-280z-22-wont-start/?&page=2#findComment-228243 Share on other sites More sharing options...
November 11, 200717 yr comment_228246 I don't think all of the connectors would go bad at once. More likely, you're not getting a signal to the injectors. Could be your ignition relay or the main fuel injection relay both of which are in the circuit that fires the injectors. Oh, and don't mess with those air bleed screws on the AFM especially with the car not running. Even if it was running I wouldn't suggest touching those unless a) you know what you're doing with them and you have some type of meter to measure air/fuel ratio, CO, HC, etc. Link to comment https://www.classiczcars.com/forums/topic/26113-1975-datsun-280z-22-wont-start/?&page=2#findComment-228246 Share on other sites More sharing options...
November 11, 200717 yr Author comment_228247 were are the relays located and are they expensive? if you could send a pic of the relays that would help Link to comment https://www.classiczcars.com/forums/topic/26113-1975-datsun-280z-22-wont-start/?&page=2#findComment-228247 Share on other sites More sharing options...
November 11, 200717 yr comment_228249 In this thread I have a couple of posts about the fuel injection relay and it's test procedure. The ignition relay is the large one in the bracket in the passenger side footwell. http://www.classiczcars.com/forums/showthread.php?p=235069&highlight=fuel+injection+relay#post235069 Link to comment https://www.classiczcars.com/forums/topic/26113-1975-datsun-280z-22-wont-start/?&page=2#findComment-228249 Share on other sites More sharing options...
November 11, 200717 yr comment_228255 the fuel pump turned on both timesCheck the fuel pressure between your filter and the engine. You can get a test kit from Harbor Freight Tools. Are you sure the fuel pump installed was for fuel injection? Carburators do not need the high pressure as fuel injection.The relay Stephen is refering to is under the drivers side on 75's. It is mounted up above the ECU. Kind of a pain to reach. Sounds like the fuel pump side is working.There should be a ground to the chasis next to the battery. Take it off and clean the connections. On my 75 I added an extra lead to the negative battery cable to. This is the ground point for the ECU.Check that ground connection first. Link to comment https://www.classiczcars.com/forums/topic/26113-1975-datsun-280z-22-wont-start/?&page=2#findComment-228255 Share on other sites More sharing options...
November 11, 200717 yr comment_228257 I had a problem very similar to this .... It was simply the fuel filter. They can stop allowing fuel through very abruptly. Check out the simple things first. Good luck with that, and keep us posted with results. Link to comment https://www.classiczcars.com/forums/topic/26113-1975-datsun-280z-22-wont-start/?&page=2#findComment-228257 Share on other sites More sharing options...
November 12, 200717 yr comment_228262 True, but he says "i know the gas gets to the injectors" (!?) and a fuel pressure check was suggested back post #7 which would have verified any clogs in the system, a bad fuel filter, or lack of enough pressure to run but that hasn't been done yet so we're still guessing. Link to comment https://www.classiczcars.com/forums/topic/26113-1975-datsun-280z-22-wont-start/?&page=2#findComment-228262 Share on other sites More sharing options...
