Car: 1977 Datsun 260Z
Owner: Tom Whitfield
Purchased: July 2004
Power: Chasing 200 RWHP (153 RWKW). Should have figures once i find a dyno day when the cars not in an event or off the road (not often :P)
ET: Low 14 second quarter (different car, same motor ran a 14.3 a couple weeks ago)
http://www.youtube.com/profile?user=whittie260
Interior:
CAMS approved 6-point roll cage
Momo Corse Racing seat
SPARCO 4 Point Race Harness
Momo Race steering wheel
Re-trimmed seats and all carpets and mats
All working and original gauges
Red-back alarm, immobilizer and remote central locking
Exterior:
Custom modified front spoiler
Custom installed 2 window sunroof
Factory option rear spoiler
Powder-coated black exterior trim pieces
Rolling Stock:
Race:
Japanese 3-piece ultra light weight 15" race rims
Dunlop 215/50/15 Type-R race semi-slick tyres all round
Street:
Original 14" Datsun mags polished and painted
195/60/14 Nankang tyres all round
Engine Bay:
Nissan L28 Engine block bored 60 thou
Nissan P90 head shaved, ported and header flowed
Gemini pistons
Nissan l24 con rods
Datrally 78 race cam
Oversize valves
Triple 45mm Weber carburetors
MSD Digital-6 Plus ignition
K&N Filters
BMW gold centered harmonic balancer
Oversized crankshaft bearings
2 1/4" mandrel bend tuned length extractors
2 1/2" mandrel bend exhaust, 3" resonator, 3" muffler
V8 2-core radiator
Mechanical:
Lightened flywheel
Re-lined Exedy super-heavy duty clutch (soon to be replaced with button clutch to handle power)
Nissan 5 speed close ratio gearbox
Nissan Skyline 4.4:1 LSD
Custom stub axles
Datsun 1600 drive shafts
Ford BA XR8 2-spot front rotors and calipers, EBC green pads
Nissan R31 Skyline 1-spot rear calipers and rotors, EBC green pads
15/16" Brake master cylinder
Koni internally adjustable struts
King springs
Aftermarket sway bars front and rear
Camber Kit
Polyurethane bushings through-out
Volkswagon H4 headlights
ICE:
You dont need a subwoofer with triple webers :twisted:
https://www.classiczcars.com/forums/topic/26122-tommo-560s-77-260/
Just the way it should be :)
Very nice car, I especially like the black around the windows instead of shiny aluminum. Nice touch!
Yeah were the fastest in class. that picture was from the vintage regularity last year which is coming up again in a few weeks. absolute ball of a time. im generally overtaking the back of the pack after 2-3 laps :devious:
as for the black. Thanks!! most people seem to think the chrome looks better
but personally chrome and silver was too much, and the black makes it look kinda stealth like so i definitely prefer it.
Noticed you fitted XR8 rotors and 4pots. Was this hard to do? Just looking at 4 pot options now (in New Zealand)
Theyre only 2-pots but they have about 2 times more pad area and much more powerful pistons than what was on the car (Toyota 4x4 4-pistons), so over stock, if thats what youve got, even over the toyotas, they would be a PHENOMENAL upgrade.
Rather easy to fit. re-drilled commodore rotors to 4-stud patter to fit on the hubs and had to shave the suspension arm where the calipers mount down to a completely flat surface (they have a slight bump. about a couple mm i believe) and then used a shim to situate the caliper centrally on the rotor.
not too difficult but not super easy.
If youre not going to be racing it id honestly recommend the Toyota 4x4 4-piston and solid or vented rotors, much easier to fit and work fine. these were on the car and did a far more than adequate job on the street, the solid rotor just got too much heat soak on the track though. fine for sprints and motorkhanas and "street" racing but could be better for circuit racing, which is why i upgraded.
the added bonus with these xr8/commodore brakes too is that they fit in under the 14" stockies :D had to use an angle grinder for one spot on one of the fins on one of the rotors that JUST touched but otherwise all good.
**EDIT** the commodore and xr8 brakes are identical i am lead to believe. i also am told that these particular specimens are from a VN commodore, but they are however identical to the brakes on all models of xr8 and commodore up to but excluding the current iterations. i am not certain of this though so some searching for "commodore brakes" on this website and/or hybridz.org would probably be prudent.
Thanks - that's excellant info.
I have an VN commodore station and an XR6T - so will be interested in comparing how these match to the 260z.
But just to clarify - are you saying that the commodore/xr8 bolt pattern matches directly to the 260z? (apart from a shim)
That's stainless steel isn't it? not aluminum.
Yes you are right mr. camo, I guess working around diesel trucks is getting to me (memory loss)
Just curious Tommo, how did you go about painting the trim? Is it powdercoated, did you sand it and paint it?
ohhh... good question. now you mention it i think they are out by a little bit so we welded and re drilled one of the holes. i dont think its out by much. sorry cant be more precise but it was a while ago and i dont really remember, just that i took it to a cnc place and said fix it. whatever they did it didnt cost much, i remember that much.
Justin: Yeah, Powder coated. flat black i think. looks great.
