Yes,I know a lot people saying about they want to build a Wangan Devil
Z,but I've never realy see some one working on,there fore ,this is
something I wouldl like to build up:A repilica Wangan Divil Z(start from
out looking)!!
there fore ,Guys I need help in few detail about it,
1.suspensing set up? I am not going to build a twin turbo engine ,at
least not right now,I am not looking for something high performance kit
also,I just simply want to dorp few inches to look like it,so which
spring kit I should be looking for?
2.tire and size,look to me It seems to be a 16 inches Watanabe RS8-R
Wheels,but where I could get those? and please suggest the right rims
and tires size?
3.this question might not the right spot,I will post there later,about
the out looking ,I've order the air dams and ZG flares,but which color
tone is that shining blue?and I need to build the flares first or I
could do it later?will the 16" tire hit the fander if the flare done
later?
thanks (needs advise)
https://www.classiczcars.com/forums/topic/26131-outlook-modify-devil-z/
  • 3 months later...
You'll need some Wantabe rims or some Rewinds, ZG Flares, a Bre spoiler, and I believe the front airdam from MSA.
That would be just for the look.
Now if you wanted to go al out you'd need to build a triple cabed weber setup with twin turbos as well as stroke the L28 with a LD28 Maxima crank.
I actually have the parts list of the actual car that inspired the Devil Z, I could post it up later. However, this is pretty much what you would need. But even then it still wouldn't be a replica because it wouldn't be a RHD model. Also I believe you'd need an early model s30z if you were using US SPEC s30's (any 240z and an early model 260z would do just fine because they are the lightest of the batch)
I personally wouldn't build a replica, build your own car. The look that Z has is actually pretty common and not as "special" as you would think.
Good luck with your Z!
Edit: Didn't notice the age of the topic please delete this post.
  • 1 year later...
