Posted November 9, 200717 yr comment_227979 Looking for a suppler fOF the brass bushings on the shifter of a 280z Link to comment https://www.classiczcars.com/forums/topic/26176-shifter-bushing/ Share on other sites More sharing options...
November 9, 200717 yr comment_227992 I just put some brass bushings in my shifter from ebay for about 15 bucks. The store link is http://motors.search.ebay.com/_W0QQsassZcaptdavetoolsor do a search for seller captdavetoolsHe has 100% feedback. I'm happy with the set I bought. Link to comment https://www.classiczcars.com/forums/topic/26176-shifter-bushing/#findComment-227992 Share on other sites More sharing options...
November 9, 200717 yr comment_227993 This might be a more economical alternative: http://www.atlanticz.ca/zclub/techtips/shifterbushing/index.html Link to comment https://www.classiczcars.com/forums/topic/26176-shifter-bushing/#findComment-227993 Share on other sites More sharing options...
November 10, 200717 yr comment_228032 I tried the brass bushings. Didn't like the 'buzz' in the shifter. The stock ones work fine, and are quieter. I make sure I keep a couple of sets on hand. Link to comment https://www.classiczcars.com/forums/topic/26176-shifter-bushing/#findComment-228032 Share on other sites More sharing options...
November 10, 200717 yr comment_228041 I don't like the atlantic Z set up, did that and it just does not fit right. Drilling and sorts. If you want quiet then use the nylon/plastic bushings if you want long life out of them, use the brass ones. Link to comment https://www.classiczcars.com/forums/topic/26176-shifter-bushing/#findComment-228041 Share on other sites More sharing options...
December 18, 200717 yr comment_231704 Thinking of getting it changed, not sure how much is involed. any input will be appreciated. Link to comment https://www.classiczcars.com/forums/topic/26176-shifter-bushing/#findComment-231704 Share on other sites More sharing options...
December 18, 200717 yr comment_231718 Thinking of getting it changed, not sure how much is involed. any input will be appreciated.Hardly any once you get the the console and the two rubber boots lifted. I used a flathead screwdriver and it took about 2 minutes. Link to comment https://www.classiczcars.com/forums/topic/26176-shifter-bushing/#findComment-231718 Share on other sites More sharing options...
December 19, 200717 yr comment_231769 Check out this website: http://www.zzxdatsun.com/ . They have a kit for sale. Link to comment https://www.classiczcars.com/forums/topic/26176-shifter-bushing/#findComment-231769 Share on other sites More sharing options...
