cebu Posted November 10, 2007 Share #1 Posted November 10, 2007 I changed my speedometer and my dash lights went out is it because of the different spedo or is it a fuse? Link to comment Share on other sites More sharing options...
Zs-ondabrain Posted November 10, 2007 Share #2 Posted November 10, 2007 most likely a fuse problem. The parking lights are usually on the same circuit so if they are still operating, it may not be a fuse but the dimmer under the dash. Also known as a Potentiometer. It's 33 yewars old and you may have shorted it out in the process of the "swap".Check the other lights, the dimmer and ALL fuses in the fuse box, both visually and with a ohms meter.Let us know what ya find,Dave. Link to comment Share on other sites More sharing options...
cebu Posted November 10, 2007 Author Share #3 Posted November 10, 2007 The dimmer is not conected. where does it conect? Link to comment Share on other sites More sharing options...
280~Master Posted November 10, 2007 Share #4 Posted November 10, 2007 Did you remove the dash?Did you put new bulbs in?Did you check the fuses?Are all the wires connected (right)?Is the battery connected?Does the car still start and run?more exact info needed to give better advice. Link to comment Share on other sites More sharing options...
cebu Posted November 10, 2007 Author Share #5 Posted November 10, 2007 Never removed the dashnever put new bulbs inchecked every fuse 4 timesthe dimmer wire is not conectedthe bettery is connected the car starts and runs great this is my only problem Link to comment Share on other sites More sharing options...
Zs-ondabrain Posted November 10, 2007 Share #6 Posted November 10, 2007 not knowing the 260Z's that well, my best advice it to look for similar plugs in that general area. It most likely got disconnected in the fight to R & R the gauges.Dave. Link to comment Share on other sites More sharing options...
cebu Posted November 10, 2007 Author Share #7 Posted November 10, 2007 I cant find it any where i dont think its there, but would it plug into the spedo? or would the new speedo have any afect on it? Link to comment Share on other sites More sharing options...
Zs-ondabrain Posted November 10, 2007 Share #8 Posted November 10, 2007 the dimmer is usually located under the Tach but I know 240Z's, not 260Z's. I can imagine that it would plug into the Speedo, on any car.The plugs have to be there somewhere. keep looking.good luck,Dave. Link to comment Share on other sites More sharing options...
beezee Posted November 10, 2007 Share #9 Posted November 10, 2007 There's a two wire plug in the speedo harness that plugs into the light dimmer - resister Wire colours red with blue tracer and black This is looking at a 260 speedo Link to comment Share on other sites More sharing options...
TomoHawk Posted November 10, 2007 Share #10 Posted November 10, 2007 If it's like a 280Z, then the dimmer control's connector is a 2-pin white plastic connector under the left eyeball vent. The mating connector to the dash lights should be nearby. You will probably need a light to crawl under there and look for it- there's a big mess under there! (At least mine is.)This is a good incentive to get yourself a copy of the wiring diagram for your car, especially if you intend to keep it a long time.thxZ Link to comment Share on other sites More sharing options...
cebu Posted November 10, 2007 Author Share #11 Posted November 10, 2007 Ok i connected the dimmer to a plug on the speedo and its still not working what do i do know? Link to comment Share on other sites More sharing options...
TomoHawk Posted November 10, 2007 Share #12 Posted November 10, 2007 "to a plug on the speedo??" I hope you didn't fry your speedometer! The dimmer control doesn't have a plug that goes to the speedometer. It goes to a mating plug that's in a nearby group of wires. If that's what you did, and the light still doesn't work, you might try bypassing the dimmer control. You'll need a wiring diagram to see which pin to use, then connect it to ground. Then if you still don't have any lights, you're in trouble... Link to comment Share on other sites More sharing options...
