Hey everyone,
This is my first post on this board. Great posts on SU's and carbs in general. I didn't find anything on this, so if I am posting a question that has already been answered in the archives, I am sorry.
I have a 3.1L build that presently has SU's with Grose-Jets on it. I will eventually go to triples or throttle bodies but for now, this is what I have. In anycase, check out the attachment. See how there are two vacuum ports, one blue and one green? The next two? I am curious as to what they were for? Any recommendation on how to plug them? Are the NPT or some BPT? If not, I imagine I'll need to just drill and tap the holes and then plug them?
Thanks,
Brett
'77 280Z
https://www.classiczcars.com/forums/topic/26259-vacuum-ports-on-su-manifolds/
I don't have a clue what someone has added these for, this a new one on me. You can just take the intake to a welder and have the holes filled or as you said tap them and screw in plugs or a bolt. As for your Grose Jets I have been reading for years in every venue not to use Grose Jets . ZTherapy would be a place to ask about them. Gary
Hey Gary,
Thanks for the reply. I rebuilt the carbs several years back with a kit from ZTherapy. I could not remember for sure which needles they were (SM, GrossJet, whathaveyou) but I found a packet the other day that said Grose Jets on them. Interesting. I'll look into it.
As for those holes, that is actually a picture of a new old stock manifold over at www.oem-surplus.com. I had originally thought that a PO had just messed with my intake, but apparently not. I'll look into it and post back. I imagine I'll just tap and plug them.
Thanks!
Brett
  • 1 month later...
