Posted November 19, 200717 yr comment_229065 I would like to fit a 6 bolt light flywheel to my L28 and found that it has 8 bolts. Yes I know that I should have checked first? Do all L28 motors have 8bolts connecting the flywheel to the crankshaft? I understood that there were supposed to be 6 like on the L26. Apart from the bolt patterns are there any other differences in the flywheels between the L24/26 and L28? Link to comment https://www.classiczcars.com/forums/topic/26284-flywheel-bolts/ Share on other sites More sharing options...
November 19, 200717 yr comment_229084 do you have a pic? i have never seen an 8-bolt flywheel... Link to comment https://www.classiczcars.com/forums/topic/26284-flywheel-bolts/#findComment-229084 Share on other sites More sharing options...
November 22, 200717 yr Author comment_229403 Photos of 8 bolt flywheel attached. Link to comment https://www.classiczcars.com/forums/topic/26284-flywheel-bolts/#findComment-229403 Share on other sites More sharing options...
November 22, 200717 yr comment_229408 Thats odd. My 280 only had 6 bolts. Link to comment https://www.classiczcars.com/forums/topic/26284-flywheel-bolts/#findComment-229408 Share on other sites More sharing options...
November 23, 200717 yr comment_229470 Ld28? Link to comment https://www.classiczcars.com/forums/topic/26284-flywheel-bolts/#findComment-229470 Share on other sites More sharing options...
November 23, 200717 yr Author comment_229475 Not sure. The motor was in a rusty 2 seater 260Z body. The kid who sold it to me said that his dad had done quite a bit of work on the motor about 15 years previously. When I took the head off I noticed that it has flat top pistons. I have been using it in my good car for club motor sport and historic regularity events. With triple webers it is producing 160 rear wheel HP. I plan on putting it back in as is for next season. Link to comment https://www.classiczcars.com/forums/topic/26284-flywheel-bolts/#findComment-229475 Share on other sites More sharing options...
November 23, 200717 yr comment_229485 LD28 has the same number of bolt holes as any other L24/L26/L28 crank. Link to comment https://www.classiczcars.com/forums/topic/26284-flywheel-bolts/#findComment-229485 Share on other sites More sharing options...
November 23, 200717 yr comment_229486 Even the cranks listed in the Nissan Competition catalog were 6 bolt. Could this be an aftermarket/speciality shop or some other type of custom setup? I'm curious now.:surprised Link to comment https://www.classiczcars.com/forums/topic/26284-flywheel-bolts/#findComment-229486 Share on other sites More sharing options...
November 23, 200717 yr comment_229497 It's not an LD28 . That also has the 6 bolt pattern with a dowel added. I thought there was a OS Giken crankshaft with this 8 bolt pattern in the early days. Link to comment https://www.classiczcars.com/forums/topic/26284-flywheel-bolts/#findComment-229497 Share on other sites More sharing options...
